ESP32 Compiling error
Has thanked: 245 times
Been thanked: 257 times
Re: ESP32 Compiling error
Hi Leigh
Yes this is the result
C:\esp-idf>export
Setting IDF_PATH: C:\esp-idf
Adding ESP-IDF tools to PATH...
No directories added to PATH:
C:\espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin;C:\espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin;C:\espressif\tools\xtensa-esp32s3-elf\esp-2020r3-8.4.0\xtensa-esp32s3-elf\bin;C:\espressif\tools\riscv32-esp-elf\1.24.0.123_64eb9ff-8.4.0\riscv32-esp-elf\bin;C:\espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin;C:\espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin;C:\espressif\tools\cmake\3.16.4\bin;C:\espressif\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\bin;C:\espressif\tools\ninja\1.10.2\;C:\espressif\tools\idf-exe\1.0.1\;C:\espressif\tools\ccache\3.7\;C:\espressif\tools\dfu-util\0.9\dfu-util-0.9-win64;C:\esp-idf\tools;C:\espressif\python_env\idf4.3_py3.8_env\Scripts\;C:\espressif\tools\idf-git\2.30.1\cmd\;C:\espressif;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\synedra\ViewPersonal;C:\Program Files (x86)\Microchip\xc32\v2.20\bin;C:\Program Files\ASUS\Bluetooth Software\;C:\Program Files\ASUS\Bluetooth Software\syswow64;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files\MATLAB\R2019b\runtime\win64;C:\Program Files\MATLAB\R2019b\bin;C:\Program Files\Git\cmd;C:\Users\stefan.erni\AppData\Local\Microsoft\WindowsApps;
Python requirements from C:\esp-idf\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
LeighM
Has thanked: 107 times
Been thanked: 302 times
Post by LeighM »
Thanks, hmm, I don't see a path to Python in that PATH.
What do you get if you now type
python --version
C:\esp-idf>python --version
Python 3.8.7
C:\esp-idf>
LeighM
Post by LeighM »
OK, thanks.
I'm still fairly sure that the problem is that the path to Python 3.8.7 is missing from the Windows PATH environment variable.
Do you know how to add it?
Hi Leigh
I know where to look but I haven't changed it yet. I'm only on the second computer on Monday, now I'm on the first computer that works fine. But I'll check on Monday whether and how the path is set for the Phython.
Printscreen from the working computer
Hi Leigh
I'm on the second computer.
You are right, the entry is missing. But the folder is also missing (user\kfs-forschung\AppData\Locals\programs\Phyton37
I tried to add some path (folder) but it never found this Python.
LeighM
Post by LeighM »
Hi Stefan,
I would suggest that you uninstall all Python, via Windows -> Settings -> Apps
Then run the ESP installer to re-install Python and follow our pdf instructions regarding settings
https://www.flowcode.co.uk/wiki/index.p ... ctions.pdf
Hi Leigh
I did, but I get a error.
Setup Log 2021-09-20 #002.txt
(43.94 KiB) Downloaded 728 times
Has thanked: 772 times
Been thanked: 831 times
I wonder if it has something to do with:
I thought there is a prompt to give admin rights?
Hi Martin
Yes you are rigth, there is a problem with the powershell.
There was no promp and on the end no powershell.
On this computer I have admin rigthts but in way limited and is behind a big big firewall.
I have to think about what to do.
