Conseil programmation
datatec73
Post by datatec73 »
Bonjour a tous
Je suis actuellement sur un projet de commande de motorisation de portail linéaire.
Le projet fonctionne très bien avec le flowcode en simulation mais quand je programme le PIC (16F88) rien ne fonctionne .
Je joins la copie de mon projet
pouvez-vous m’aider ou me donner des conseils.
Merci de votre aide.
Christian
portail bissy new 01-08-21_V6_.fcfx
(79.55 KiB) Downloaded 533 times
jgu1
Has thanked: 910 times
Been thanked: 220 times
Re: Conseil programmation
Post by jgu1 »
Hello!
I cannot speak french, I used translate.
As far I see you use a 4Mhz X tal and in config you have setup to Osc: HS As far I remember you need to use Osc: XT and LOW voltage was enabled, I disable this
And is resetpin high pin 4?
I have change the config, maybe it help :D .
Br Jorgen
portail bissy new 01-08-21_V7_.fcfx
(79.11 KiB) Downloaded 596 times
datatec73
Post by datatec73 »
I don't speak English and I also use the translator.
thank you for your advice and help I try to program with this option.
I will keep you informed of the result.
Christian
