unity-control
- Has thanked: 23 times
- Been thanked: 11 times
Post
by unity-control »
Hi guys,
Maybe I'm doing something wrong here like my logic isn't right... but the emulation of SSD1306 doesn't seem to be working correctly
Little subprogram as follows:
- sub_program.jpg (40.52 KiB) Viewed 4484 times
The OLED shows the right image:
- oled_read_reg_correct.jpg (13.08 KiB) Viewed 4484 times
But the FC emulation (2D/3D Panel and Bitmap/Point Cloud modes) isn't right:
- fc_gLCD_emulation.jpg (22.18 KiB) Viewed 4484 times
Thanks for your help!
R
unity-control
Post
by unity-control »
Not a known issue?
Is it possible to get the GLCD (SSD1306 Buffered) component source at all to have a check?
Cheers!
R
- Has thanked: 647 times
- Been thanked: 856 times
Post
by BenR »
It looks like the simulated pixel colours are backwards once you set the fg/bg colours, I'll see if we can get that sorted for you.
Edit, should be fixed for you now.
unity-control
Post
by unity-control »
THANKS for this fix, all working perfectly fine now!
- ssd1306_working.jpg (31.93 KiB) Viewed 4348 times
Cheers,
R
