Flowcode V9 Won't Start
cwpiv2
After upgrading to V9 from V6 I can not start Flowcode. Please see attached screen snips for details. I'm running Windows 10 Pro fully updated as of today.
- Has thanked: 795 times
- Been thanked: 858 times
Re: Flowcode V9 Won't Start
The error you are facing will be more to do with a PC issue rather than Flowcode.
For example, a third-party AV or firewall is preventing Flowcode to access the Windows DLL file.
Or the file itself could be corrupt?
When Flowcode is first installed, I don't believe glu32.dll is a file that is installed.
- Has thanked: 311 times
- Been thanked: 479 times
Searching the internet, it looks like this is either a problem with Windows or with the graphics card drivers. Most suggestions seem to follow this order:
1) Start Windows in Safe Mode
2) Run the Windows System File Checker (SFC) tool
3) Update drivers for your graphics card
Please try this and let us know how you get on.
Thanks Steve-Matrix, I had found the same but wanted to check if there was a known issue before doing the screen time. There were a few more steps to do, but fundamentally your solution worked. I'll post the rest of the steps when I get a chance.
