Mega 2560 API ADC Issue
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Hi Team,
I am not sure what I am doing wrong however using the ARduino mega2560 API-Scada the ADC Sample8 is working fine but the Sample10 is give absolute wrong and impossible values.Samples taking on the same channel(A0) one is correct and the other is not any help appreciated :D
ScadaTest.fcfx
(10.77 KiB) Downloaded 531 times
Has thanked: 724 times
Been thanked: 783 times
Re: Mega 2560 API ADC Issue
Hi Peter.
Can you try with the attached component, please?
Hopefully, after adding component, then reloading App Dev it will work as intended?
SCADA_Ard_Mega Comp.zip
(8.72 KiB) Downloaded 504 times
p.erasmus
Post by p.erasmus »
Hi Martin.
Thank you for your help however I am not sure were this FCDX file must go to V9 >>> FCD ARD or to SCADA
Thanks for the help
Hi Peter.
As the file has a fcpx extension then it's a component.
In file explorer address bar, paste this:
C:\ProgramData\MatrixTSL\FlowcodeV9\Components
Extract the component within the attached zip file and save it into the above hidden folder.
Just select ok to replace the current file.
If you got Flowcode running when file was placed in the components directory, you must select the reload icon before compiling again.
p.erasmus
Post by p.erasmus »
Thanks Martin :D
Apprceiate will do
p.erasmus
Post by p.erasmus »
Thanks that is working perfectly now :D
Fc wants me to update the same file now when I open the FC project if I do that then it seems it updates to the old file and things stop to work again :D
I then placed the file again and did not update FC so it is working now but in future if there is other updates it mights swtopped again to work
just to inform I am ok for now I can do what I need to do
Thanks again.
Hi, Peter.
You're welcome.
The component is only temporary until Ben pushes the update onto the system.
It's showing Not genuine since the update is manually added and not via the download button.
When the new revision is 9 instead of 8 then you can download it, and override the Not genuine version.
I will let you know when it's available.
For now, you can leave it as showing Not genuine so your App Developer is working as expected.
Don't forget you can untick the component if there are other updates as well, but if there are new updates then SCADA_Ard_Mega.fcpx will be one of them.
Thank you for letting me know the new version works.
p.erasmus
Post by p.erasmus »
Thanks Martin :D
