DAC on PIC12F1572
Sergejs
Has thanked: 75 times
Been thanked: 5 times
DAC on PIC12F1572
Post by Sergejs »
Hello, dear friends!
Why if use DAC on PIC12F1572 Flowcode can not compile *.hex file? How can it be resolved?
Has thanked: 607 times
Been thanked: 803 times
Re: DAC on PIC12F1572
Please can you attach your .fcfx Flowcode project file and also maybe the .msg.txt file that is produced showing the errors being generated.
Sergejs
Post by Sergejs »
Ok. This is files what you ask.
12lf1572_dac.msg.txt
(2.3 KiB) Downloaded 578 times
12lf1572_dac.fcfx
(7.58 KiB) Downloaded 588 times
Thanks for letting us know.
The problem is caused by the datasheet and the compiler device definitions being slightly different.
I've fixed the problem for you now via the library updates system.
Sergejs
Post by Sergejs »
Many thanks!
