Hello, dear friends!
Why if use DAC on PIC12F1572 Flowcode can not compile *.hex file? How can it be resolved?
DAC on PIC12F1572
Sergejs
- Has thanked: 75 times
- Been thanked: 5 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: DAC on PIC12F1572
Please can you attach your .fcfx Flowcode project file and also maybe the .msg.txt file that is produced showing the errors being generated.
Thanks for letting us know.
The problem is caused by the datasheet and the compiler device definitions being slightly different.
I've fixed the problem for you now via the library updates system.
