PIC24FJ512GA606 download error!
seokgi
Has thanked: 8 times
Been thanked: 9 times
Post by seokgi »
I have a question.
I'm working on a project using PIC24FJ512GA606.
When I select the project option and compile and download it, an error that the device is not recognized appears.
And when I look at the project options again, I see the other chip selected. How to solve it?
Please help.
thank you.
FITech
Has thanked: 2 times
Been thanked: 2 times
Re: PIC24FJ512GA606 compile error!
Post by FITech »
Looking at the PLL Block for the chip, max system CLK is 32MHz.
You need to lookup the datasheet to see what Configuration Bits and necessary registers to set.
PLL BLock.png (65 KiB) Viewed 11314 times
seokgi
Post by seokgi »
Thank you for answer.
But the key is that the compiled data is not downloaded to the mcu.
kersing
Has thanked: 81 times
Been thanked: 65 times
Re: PIC24FJ512GA606 download error!
Post by kersing »
The PICkit detects an DSPIC33FJ32MC302, so either you are using the wrong chip or you need to check your hardware setup.
By the way, next time you post compiler output please go to the ….msg.txt file in your flowchart folder and copy-and-paste the text in the file, not a screenshot for easier reading for us.
seokgi
Post by seokgi »
I post the message file.
Auto_Lifting_Lamp_CTL_211228_1-PIC24FJ512GA606.msg.txt
(9.59 KiB) Downloaded 746 times
kersing
Post by kersing »
What is your hardware? What is connected to what?
seokgi
Post by seokgi »
I'm connected PICKIT3 to PIC24FJ512GA606.
kersing
Post by kersing »
A bit more information would not hurt. How did you connect the two? Which pin to which pin? What else is connected?
seokgi
Post by seokgi »
Post my drawings.
seokgi
Post by seokgi »
MPLAB IPE downloads normally.
Please make it work in FC9.
