PIC16F1823 NEC_IR decoder
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Good morning!
I am making NEC_IR decoder using PIC16F1823. I'm trying to program by referring to various data, but it doesn't work.
I referenced RC5(38KHz) of FC9 but it doesn't work.
How should I proceed?
Has thanked: 292 times
Been thanked: 458 times
Re: PIC16F1823 NEC_IR decoder
The best way to get help for problems like this is to do the following:
  • Describe in detail the specific problem that is not working
  • Say if this a problem in simulation or when downloaded to a target device (or both)
  • Provide a simple example that shows the problem and give the steps to replicate it (.fcfx project file along with .c and .msg.txt if relevant)
seokgi
Post by seokgi »
Thank you for your attention.
This is my program.
Cleaner-220111-1NEC_IR.fcfx
(22.53 KiB) Downloaded 311 times
Has thanked: 724 times
Been thanked: 783 times
Hi.
The NEC and RC5 are two different protocols.
Therefore the RC5 component will not work decoding NEC Remote controls.
Has thanked: 616 times
Been thanked: 815 times
NEC doesn't look too bad. I'll investigate and see if we can craft a component to receive and transmit this.
