Good morning!
I am making NEC_IR decoder using PIC16F1823. I'm trying to program by referring to various data, but it doesn't work.
I referenced RC5(38KHz) of FC9 but it doesn't work.
How should I proceed?
PIC16F1823 NEC_IR decoder
seokgi
- Has thanked: 8 times
- Been thanked: 8 times
- Has thanked: 269 times
- Been thanked: 442 times
Re: PIC16F1823 NEC_IR decoder
The best way to get help for problems like this is to do the following:
- Describe in detail the specific problem that is not working
- Say if this a problem in simulation or when downloaded to a target device (or both)
- Provide a simple example that shows the problem and give the steps to replicate it (.fcfx project file along with .c and .msg.txt if relevant)
Thank you for your attention.
This is my program.
This is my program.
- Cleaner-220111-1NEC_IR.fcfx
- (22.53 KiB) Downloaded 304 times
- Has thanked: 595 times
- Been thanked: 785 times
NEC doesn't look too bad. I'll investigate and see if we can craft a component to receive and transmit this.
