ESP32 Board with AXP192 Power management
Has thanked: 234 times
Been thanked: 252 times
On my board I have AXP192 Power management IC.
I like to read a register and later write in the register
I have a sample code but I don't know to translate this in flowcode.
I'm always reading 255
here the democode:
uint8_t AXP192::Read8bit( uint8_t Addr )
Wire1.beginTransmission(0x34);
Wire1.write(Addr);
Wire1.endTransmission();
Wire1.requestFrom(0x34, 1);
return Wire1.read();
Here my program:
FC9_M5Stack1_spi_display_adx192-1.fcfx
(14.4 KiB) Downloaded 589 times
Some info about all the register:
https://github.com/RolandoMagico/TTGO-T ... nformation
and the democode:
https://github.com/m5stack/M5StickC/blo ... AXP192.cpp
Has thanked: 616 times
Been thanked: 814 times
Re: ESP32 Board with AXP192 Power management
Hi Stefan,
You were on the right track.
Give this a whirl, fingers crossed :D
(15.58 KiB) Downloaded 705 times
Here's another version with the write function.
(17.22 KiB) Downloaded 716 times
I tried both versions but I always get 0. With the oscilloscope I have clock and data on the correct pin.
I think the register 32h is 0.
I tried some another register with your first code and there I get the correct value.
Hi Stefan
In the example code there is a far bit in the initialise function code. It might be it needs setting up to work as expected?
