Transferring data with Modbus RTU
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
I need your help
how do I implement the following code under Modbus RTU?
Slave address 0x01
Function code 0x06
Register address 0x0000
The value for the register e.g. 0x0960
CRC Checksum 0x8FB2 =16Bit Start Preloading a 16-bit register to all 1's =65535
The code is used to set a power supply voltage to 24 volts.
Use a serial interface for this.
The hex values are taken from the operating instructions for the DPH5005 power supply unit.
mfg SpeedPic32
SpeedPIC32
Re: Transferring data with Modbus RTU
Can the power supply unit be made into a component? Joy-IT JT-DPH5005
Sincerely SpeedPic32
JOY-IT_DPH5005_DS-EN.pdf
(295.32 KiB) Downloaded 747 times
SpeedPIC32
DPS5005USB.pdf
(1.3 MiB) Downloaded 707 times
Has thanked: 650 times
Been thanked: 856 times
Are you trying to communicate with a slave device or create a slave device?
Function code 6 is the SetHoldingRegister command for the Master.
This example might help show how things work from the Master point of view.
Modbus_Example.fcfx
(8.79 KiB) Downloaded 586 times
The power supply looks interesting, I'll see if I can find some time today to start some macros to drive it to help show you how we might go about creating a component.
Here's a simple program with some macros to read/write the output voltage and current.
Modbus_Example_DPH5005.fcfx
(22.44 KiB) Downloaded 816 times
The slave address is assigned via a property and I've exposed a few other Modbus specific properties so you can configure them if exported as a component.
Let us know how you get on.
SpeedPIC32
hello,
unfortunately there are errors
With kind regards
SpeedPic32
Target folder: C:\Users\uwe\Documents\Daten\Flowcode_Projekte
Source name: C:\Users\uwe\Documents\Daten\Flowcode_Projekte\Modbus_Example_DPH5005.fcfx
Device: PIC32.32MZ.32MZ2048EFH100
Generated by: Flowcode v9.2.0.33
Date: Friday, January 28, 2022 15:20:30
Registered to: SpeedPic32 (24146314)
Licence key: ACFPTQ
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Using <IDC USB> user settings for compiler
Launching the compiler...
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat "32MZ2048EFH100" "C:\Users\uwe\Documents\Daten\Flowcode_Projekte\" "Modbus_Example_DPH5005" "32MZ"
Project Modbus_Example_DPH5005
Device 32MZ2048EFH100
Objects Modbus_Example_DPH5005_32MZ2048EFH100
C:\Users\uwe\Documents\Daten\Flowcode_Projekte>xc32-gcc -mprocessor=32MZ2048EFH100 -DMX_USBHS -I"C:\Users\uwe\Documents\Daten\Flowcode_Projekte\." -I"C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC" -I"C:\microchip\harmony\v1_11" -I"C:\microchip\harmony\v1_11\framework" -w -c -ffunction-sections -O1 -o "Modbus_Example_DPH5005_32MZ2048EFH100\Modbus_Example_DPH5005.o" "Modbus_Example_DPH5005.c" -DMX_USBHS
Modbus_Example_DPH5005.c: In function 'FCD_05481_cal_uart__ControlPin':
Modbus_Example_DPH5005.c:445:40: error: macro "GET_PORT_MASK" requires 2 arguments, but only 1 given
Modbus_Example_DPH5005.c:445:18: error: 'GET_PORT_MASK' undeclared (first use in this function)
Modbus_Example_DPH5005.c:445:18: note: each undeclared identifier is reported only once for each function it appears in
Modbus_Example_DPH5005.c: In function 'FCD_05481_cal_uart__Prv_SimShowWaveform':
Modbus_Example_DPH5005.c:674:29: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
Modbus_Example_DPH5005.c:674:4: error: 'SET_PORT_MASK' undeclared (first use in this function)
Modbus_Example_DPH5005.c:685:31: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
Modbus_Example_DPH5005.c:690:31: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
// .Data = .Data >> 1
Modbus_Example_DPH5005.c:703:29: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
//Code has been optimised out by the pre-processor
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat reported error code 0x1
Autoclose turned off
Without seeing your project I'm just guessing but it looks like some of the pin connections for the Modbus component are not defined correctly.
SpeedPIC32
That was my mistake.
I saved the project in a new folder, hence the error.
now it runs. Thanks
With kind regards
SpeedPic32
