I need your help
how do I implement the following code under Modbus RTU?
Slave address 0x01
Function code 0x06
Register address 0x0000
The value for the register e.g. 0x0960
CRC Checksum 0x8FB2 =16Bit Start Preloading a 16-bit register to all 1's =65535
The code is used to set a power supply voltage to 24 volts.
Use a serial interface for this.
The hex values are taken from the operating instructions for the DPH5005 power supply unit.
mfg SpeedPic32
Transferring data with Modbus RTU
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
SpeedPIC32
Re: Transferring data with Modbus RTU
Can the power supply unit be made into a component? Joy-IT JT-DPH5005
Sincerely SpeedPic32
- JOY-IT_DPH5005_DS-EN.pdf
- (295.32 KiB) Downloaded 721 times
SpeedPIC32
- Has thanked: 615 times
- Been thanked: 814 times
Are you trying to communicate with a slave device or create a slave device?
Function code 6 is the SetHoldingRegister command for the Master.
This example might help show how things work from the Master point of view.
The power supply looks interesting, I'll see if I can find some time today to start some macros to drive it to help show you how we might go about creating a component.
Here's a simple program with some macros to read/write the output voltage and current.
The slave address is assigned via a property and I've exposed a few other Modbus specific properties so you can configure them if exported as a component.
Let us know how you get on.
SpeedPIC32
hello,
unfortunately there are errors
With kind regards
SpeedPic32
Target folder: C:\Users\uwe\Documents\Daten\Flowcode_Projekte
Source name: C:\Users\uwe\Documents\Daten\Flowcode_Projekte\Modbus_Example_DPH5005.fcfx
Device: PIC32.32MZ.32MZ2048EFH100
Generated by: Flowcode v9.2.0.33
Date: Friday, January 28, 2022 15:20:30
Registered to: SpeedPic32 (24146314)
Licence key: ACFPTQ
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Using <IDC USB> user settings for compiler
Launching the compiler...
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat "32MZ2048EFH100" "C:\Users\uwe\Documents\Daten\Flowcode_Projekte\" "Modbus_Example_DPH5005" "32MZ"
Project Modbus_Example_DPH5005
Device 32MZ2048EFH100
Objects Modbus_Example_DPH5005_32MZ2048EFH100
C:\Users\uwe\Documents\Daten\Flowcode_Projekte>xc32-gcc -mprocessor=32MZ2048EFH100 -DMX_USBHS -I"C:\Users\uwe\Documents\Daten\Flowcode_Projekte\." -I"C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC" -I"C:\microchip\harmony\v1_11" -I"C:\microchip\harmony\v1_11\framework" -w -c -ffunction-sections -O1 -o "Modbus_Example_DPH5005_32MZ2048EFH100\Modbus_Example_DPH5005.o" "Modbus_Example_DPH5005.c" -DMX_USBHS
Modbus_Example_DPH5005.c: In function 'FCD_05481_cal_uart__ControlPin':
Modbus_Example_DPH5005.c:445:40: error: macro "GET_PORT_MASK" requires 2 arguments, but only 1 given
Modbus_Example_DPH5005.c:445:18: error: 'GET_PORT_MASK' undeclared (first use in this function)
Modbus_Example_DPH5005.c:445:18: note: each undeclared identifier is reported only once for each function it appears in
Modbus_Example_DPH5005.c: In function 'FCD_05481_cal_uart__Prv_SimShowWaveform':
Modbus_Example_DPH5005.c:674:29: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
Modbus_Example_DPH5005.c:674:4: error: 'SET_PORT_MASK' undeclared (first use in this function)
Modbus_Example_DPH5005.c:685:31: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
Modbus_Example_DPH5005.c:690:31: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
// .Data = .Data >> 1
Modbus_Example_DPH5005.c:703:29: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
//Code has been optimised out by the pre-processor
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat reported error code 0x1
Autoclose turned off
With kind regards
SpeedPic32
Licence key: ACFPTQ
Without seeing your project I'm just guessing but it looks like some of the pin connections for the Modbus component are not defined correctly.
SpeedPIC32
That was my mistake.
I saved the project in a new folder, hence the error.
now it runs. Thanks
With kind regards
SpeedPic32
now it runs. Thanks
With kind regards
SpeedPic32
