Flowcode crashs when clicking "Build"
Leonard_de_Vinci
Post by Leonard_de_Vinci »
Hello from France,
In Flowcode 9 / Windows 10 v.1709
When I start an empty project and if I click on "build", Flowcode display this error message: "Flowcode has encountered a problem from which is unable to recover. Please save your work and then close and re-start Flowcode":
Clipboard 3.jpg (79.5 KiB) Viewed 3660 times
I Uninstall / Re-install flowcode with no change. Tried to start it as administrator with no change.
If it could help you, I used "ProcessMonitor" to find what happens when I click on "Build":
Clipboard 1.jpg (265.01 KiB) Viewed 3660 times
Clipboard 2.jpg (88.73 KiB) Viewed 3660 times
I checked that the current user has write privileges into the directory "appdata", OK.
This happens on some computers only, others works normally...
Thanks for your support
Nicolas
Has thanked: 311 times
Been thanked: 479 times
Re: Flowcode crashs when clicking "Build"
Bonjour.
This thread has a discussion of this problem:
viewtopic.php?p=3301#p3301
The solution seems to be to run the "library updates" and then restart Flowcode. Please let me know if this solves your problem.
Leonard_de_Vinci
Hello Steve,
Well, it works after a library update :roll:
Thanks for your reply !
Nicolas
