How to know which modification are done on components?
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Re: How to know which modification are done on components?
Post by Xbiotec »
oh Yes thx !
Seb
Has thanked: 650 times
Been thanked: 856 times
What errors are you getting with the latest version?
I have removed the need for the supplementary code in the latest version so maybe that's causing the problem if the time variable is being declared twice?
Xbiotec
Post by Xbiotec »
I'm just back.
I will check now
Seb
Xbiotec
Post by Xbiotec »
do I need to remove the complete code ?
#include "esp_sntp.h"
void time_sync_notification_cb(struct timeval *tv)
    ESP_LOGI(TAG, "Notification of a time synchronization event");
time_t now;
struct tm timeinfo;
Seb
Hi Seb,
Yes none of it should be required so you can try and comment it all out with some
code
Or simply uncheck the use supplementary code tickbox in the project options.
Xbiotec
Post by Xbiotec »
Supplementary code disable with RTC_ESP32_NTP V4 Build failed
ESP32_V4.2.2.msg.txt
(107.33 KiB) Downloaded 872 times
Supplementary code enable with RTC_ESP32_NTP V3 Build Ok
ESP32_V4.2.2.msg1.txt
(101.22 KiB) Downloaded 948 times
Seb
Xbiotec
Post by Xbiotec »
Hi ben,
Did you check what is the problem with new version of RTC_ESP32_NTP ?
Please check you MP. thx
Seb
Xbiotec
Post by Xbiotec »
no news about RTC ESP32 NTP.fcpx V4 issue ?
Seb
