ST7789 display
jgu1
Has thanked: 900 times
Been thanked: 218 times
Re: ST7789 display
Post by jgu1 »
Hi Martin, yes please, very welcome :D
Jorgen
Has thanked: 792 times
Been thanked: 851 times
Re: ST7789 display
Ben & I discussed this yesterday evening.
We know it's not ideal.
After converting the temperature value to a string called TemperatureString for example.
You can use
TemperatureString = TemperatureString + " \xA7\x43   "
The
\xA7
generates the
º
 \x43
generates the
C
That's if you want it to look like
ºC
jgu1
Re: ST7789 display
Post by jgu1 »
Thank you Martin. :D I will make a test. As you see I have made a project using the circle.
Just perform a test on a Ili9341 Only the C is on the screen?
I will not hijack the tread ;)
Re: ST7789 display
That looks great!
It was Ben that came up with the
\xA7\x43
& I did the testing.
It was a joint effort.
WingNut
Has thanked: 56 times
Been thanked: 43 times
Re: ST7789 display
Post by WingNut »
Yeah I cant get it to work
Re: ST7789 display
Have you followed the post Sat Mar 05, 2022 5:18 pm?
Have you also completed a Full database update?
WingNut
Re: ST7789 display
Post by WingNut »
Apologies I didn't read all of the thread - works a treat. Basically the hex value of the characters.
jollybv
Has thanked: 42 times
Been thanked: 15 times
Re: ST7789 display
Post by jollybv »
Hi guys
I have tried this but no luck have dun full update and everything not sure what I,m doing wrong
Degree symbole.PNG (12.45 KiB) Viewed 10137 times
Re: ST7789 display
Hi Brian.
Have you tried with the default or system font?
They are the only fonts that currently have the degrees symbol.
Has thanked: 646 times
Been thanked: 855 times
Re: ST7789 display
If you need another font supporting then let us know which font you're using and we can draw up the pixel artwork for the character.
