Escape Characters
alanwms
Has thanked: 27 times
Been thanked: 8 times
Escape Characters
Post by alanwms »
[Disclaimer - I don't think this has anything to do with Flowcode issues].
Wondering if you can give me some input.
Sending serial data to a terminal program called "Termite". everything is working good with the exception of a line return ("\r")
New line ("\n") pushes the cursor to the next line, but I want to rewrite on the same line by returning the curser to the beginning.
The ("\r") character sends the curser to the next line.
Maybe this is a "termite" issue. Any thoughts?
Has thanked: 778 times
Been thanked: 839 times
Re: Escape Characters
You are correct in what you are stating.
From what I can see, it appears that Termite does not accept escape characters.
If you want free software that does what you require, then try Tera Term
It even has a debug mode that allows you to see escape and non ASCII characters.
alanwms
Post by alanwms »
Thanks for the recommendation - That terminal sends out characters as they are typed into the keyboard. Does not allow for a string to be subsequent to an enter key.
It has a file send option, if that is of any use?
Has thanked: 471 times
Been thanked: 701 times
Post by chipfryer27 »
I use Terminal, another free offering. It's a bit old but has many features I find useful (https://sites.google.com/site/terminalbpp/).
There is also Realterm that has the following sending options:
Realterm send options.png (48.22 KiB) Viewed 5821 times
