Uploading code to ECIO 28P
CMoore
Has thanked: 1 time
Post by CMoore »
The issue I am having is when I try to compile to target which is a ECIO 28p chip, I get the error PIC compiler toolchain not installed even once I had installed the appropriate drivers. the driver I installed was the 8 bit PIC toolchain.
Thanks in advance.
LeighM
Has thanked: 103 times
Been thanked: 302 times
Re: Uploading code to ECIO 28P
Post by LeighM »
Can you check the PIC toolchain path in Flowcode "Global Settings" -> "Locations" ?
CMoore
Has thanked: 1 time
Post by CMoore »
Hello, this has helped as I had nothing selected in that but i now get the below error in the compiler messages tab.
Description:
Device:        PIC.18F.18F2455
Generated by:  Flowcode v9.2.0.33
Date:          Friday, April 01, 2022 16:55:46
Users:         1
Registered to: CMoore (77118090)
Licence key: ZU1VWV
   NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
Employing 18F2455 errata work-arounds:
 * Corrupted fast interrupt shadow registers
Memory Summary:
Compilation successful!
Launching the programmer...
No PICkit 2 found.
Autoclose turned off
FINISHED
Has thanked: 724 times
Been thanked: 783 times
What you need to do is Select Build, Compiler Options
Select E-Blocks just under the PIC section, then make sure Default compiler for the platform C for PIC is selected.
Compiler Options.png (40.68 KiB) Viewed 3063 times
I have placed the compiler messages within the Code tags.
You can do that and load attachments by selecting Full Editor & Preview.
Highlight the code, then select the </> tag.
