toolchain PI pico
max.tisc
Been thanked: 12 times
toolchain PI pico
Post by max.tisc »
Good morning
I am starting to try the PI pico board and I have problems with the installation of the toolchain, following the PDF on the wiki I see that the current versions of the required software have changed, I ask you if I have to install suggested versions or can I install latest ones, if you indicate the old ones versions any update requests are to be done? you will have to install the toolchain on a desktop with Win10 and a laptop with Win11
thank you
Has thanked: 724 times
Been thanked: 783 times
Re: toolchain PI pico
I created a post about that here.
I hope that helps?
max.tisc
Post by max.tisc »
Hi Medelec35
I had already read that post yesterday, now I have uninstalled everything and I try to download exactly the versions indicated
I'll let you know thanks
max.tisc
Post by max.tisc »
in these days I have uninstalled and reinstalled with the versions indicated many and many times (also FC9) following the guide and the various posts, but FC9 does not compile, both on laptop with W11 and desktop with W10, I am attaching the files created in the hope that find the problem.
Is this the only way to compile with FC9?
help help help
thank you
picoled.zip
(328.9 KiB) Downloaded 535 times
Can you check that Visual Studio Developer Tools is correctly installed?
To do that select the Start menu and type develop
If it's installed you should see:
Developer Tools.png (44.4 KiB) Viewed 6821 times
That is on my Win10 PC.
I have just checked on my windows 11 PC and I also get the Developer command prompt for VS 2019 appear on it as well.
Open the Developer Command Prompt for VS 2019 and you should see:
Developer Com Prom.png (10.27 KiB) Viewed 6821 times
Is that what you see?
If not, then you have an issue with VS BuildTools 2019
This is what I get when I compile your flowchart for the first time.
https://www.flowcode.co.uk
Using FCD settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PICO\Batch\pico_build.bat  "D:\Pico-sdk\" "picoled" "D:\Flowcode Testing\"
D:\Flowcode Testing>REM CRC: 11E85D0BF540A03612B9D5AB8A950728A3654FDC084B783F85B503651504FC6E8DA967745A187CF8FECF9115B25085A2774D1D3D69D8A99EE7320EAE740A5DB66BD212DE98DE91D9E3564078A19D1616A5C2ACA5856A86664D00059D79589982019B1EBDA9F75E245824CF181DE22D23B9DE25CDF0E36405D9066202E94705CBBDB038842E43FA4AAC72934211FD4B5DCC661788BEC7C91A063848616D51551DB978AC1A4BAF29AD4517DCDD22FC70DE135D32748FB3D1732C3050DA273BE4EE39DD52E8224900600B1F9528E97AB0BA001B0922CEB719397C7C0C9FABE651313F9A05C84301D1C0
D:\Flowcode Testing>REM REVISION: 2.0
D:\Flowcode Testing>REM GUID: 9EF5601F-D979-495F-89EB-F1C4F35D9212
D:\Flowcode Testing>REM DATE: 30\07\2021
D:\Flowcode Testing>REM DIR: FCD\PICO\batch\pico_build.bat
Building picoled ...
** Visual Studio 2019 Developer Command Prompt v16.11.10
** Copyright (c) 2021 Microsoft Corporation
Using PICO_SDK_PATH from environment ('D:\Pico-sdk\')
PICO_SDK_PATH is D:/Pico-sdk
Defaulting PICO_PLATFORM to rp2040 since not specified.
Defaulting PICO platform compiler to pico_arm_gcc since not specified.
-- Defaulting build type to 'Release' since not specified.
PICO compiler is pico_arm_gcc
CMake Warning at D:/Pico-sdk/pico_sdk_init.cmake:53 (message):
  pico_sdk_init() should be called after the project is created (and
  languages added)
Call Stack (most recent call first):
  CMakeLists.txt:10 (pico_sdk_init)
-- The C compiler identification is GNU 10.2.1
-- The CXX compiler identification is GNU 10.2.1
-- The ASM compiler identification is GNU
-- Found assembler: C:/Program Files (x86)/GNU Arm Embedded Toolchain/10 2020-q4-major/bin/arm-none-eabi-gcc.exe
Defaulting PICO target board to pico since not specified.
Using board configuration from D:/Pico-sdk/src/boards/include/boards/pico.h
-- Found Python3: C:/Users/medel/AppData/Local/Programs/Python/Python37/python.exe (found version "3.7.3") found components: Interpreter
TinyUSB available at D:/Pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040; enabling build support for USB.
-- Configuring done
-- Generating done
-- Build files have been written to: D:/Flowcode_Testing/picoled
Microsoft (R) Program Maintenance Utility Version 14.29.30140.0
Copyright (C) Microsoft Corporation.  All rights reserved.
[  1%] Creating directories for 'ELF2UF2Build'
[  3%] No download step for 'ELF2UF2Build'
[  4%] No update step for 'ELF2UF2Build'
[  6%] No patch step for 'ELF2UF2Build'
[  8%] Performing configure step for 'ELF2UF2Build'
-- The C compiler identification is MSVC 19.29.30140.0
-- The CXX compiler identification is MSVC 19.29.30140.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30133/bin/Hostx86/x86/cl.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30133/bin/Hostx86/x86/cl.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: D:/Flowcode_Testing/picoled/elf2uf2
[  9%] Performing build step for 'ELF2UF2Build'
[ 50%] Building CXX object CMakeFiles/elf2uf2.dir/main.cpp.obj
main.cpp
D:\Pico-sdk\tools\elf2uf2\main.cpp(331): warning C4996: 'fopen': This function or variable may be unsafe. Consider using fopen_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
D:\Pico-sdk\tools\elf2uf2\main.cpp(337): warning C4996: 'fopen': This function or variable may be unsafe. Consider using fopen_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
[100%] Linking CXX executable elf2uf2.exe
[100%] Built target elf2uf2
[ 11%] No install step for 'ELF2UF2Build'
[ 12%] Completed 'ELF2UF2Build'
[ 12%] Built target ELF2UF2Build
Scanning dependencies of target bs2_default
[ 14%] Building ASM object pico-sdk/src/rp2_common/boot_stage2/CMakeFiles/bs2_default.dir/compile_time_choice.S.obj
[ 16%] Linking ASM executable bs2_default.elf
[ 16%] Built target bs2_default
[ 17%] Generating bs2_default.bin
[ 19%] Generating bs2_default_padded_checksummed.S
[ 19%] Built target bs2_default_padded_checksummed_asm
Scanning dependencies of target flowcode
[ 20%] Building C object CMakeFiles/flowcode.dir/flowcode.c.obj
[ 22%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_stdlib/stdlib.c.obj
[ 24%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_gpio/gpio.c.obj
[ 25%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_claim/claim.c.obj
[ 27%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_platform/platform.c.obj
[ 29%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_sync/sync.c.obj
[ 30%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_uart/uart.c.obj
[ 32%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_divider/divider.S.obj
[ 33%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_time/time.c.obj
[ 35%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_time/timeout_helper.c.obj
[ 37%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_timer/timer.c.obj
[ 38%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_sync/sem.c.obj
[ 40%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_sync/lock_core.c.obj
[ 41%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_sync/mutex.c.obj
[ 43%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_sync/critical_section.c.obj
[ 45%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_util/datetime.c.obj
[ 46%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_util/pheap.c.obj
[ 48%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/common/pico_util/queue.c.obj
[ 50%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_runtime/runtime.c.obj
[ 51%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_clocks/clocks.c.obj
[ 53%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_irq/irq.c.obj
[ 54%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S.obj
[ 56%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_pll/pll.c.obj
[ 58%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_vreg/vreg.c.obj
[ 59%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_watchdog/watchdog.c.obj
[ 61%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_xosc/xosc.c.obj
[ 62%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_printf/printf.c.obj
[ 64%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_bit_ops/bit_ops_aeabi.S.obj
[ 66%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_bootrom/bootrom.c.obj
[ 67%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_divider/divider.S.obj
[ 69%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_double/double_aeabi.S.obj
[ 70%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_double/double_init_rom.c.obj
[ 72%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_double/double_math.c.obj
[ 74%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_double/double_v1_rom_shim.S.obj
[ 75%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_int64_ops/pico_int64_ops_aeabi.S.obj
[ 77%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_float/float_aeabi.S.obj
[ 79%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_float/float_init_rom.c.obj
[ 80%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_float/float_math.c.obj
[ 82%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_float/float_v1_rom_shim.S.obj
[ 83%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_malloc/pico_malloc.c.obj
[ 85%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_mem_ops/mem_ops_aeabi.S.obj
[ 87%] Building ASM object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_standard_link/crt0.S.obj
[ 88%] Building CXX object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_standard_link/new_delete.cpp.obj
[ 90%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_standard_link/binary_info.c.obj
[ 91%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_stdio/stdio.c.obj
[ 93%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/pico_stdio_uart/stdio_uart.c.obj
[ 95%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_adc/adc.c.obj
[ 96%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_spi/spi.c.obj
[ 98%] Building C object CMakeFiles/flowcode.dir/D_/Pico-sdk/src/rp2_common/hardware_i2c/i2c.c.obj
[100%] Linking CXX executable flowcode.elf
[100%] Built target flowcode
Build completed successfully
Using FCD settings for linker
C:\Program Files (x86)\Flowcode v9\data\tools\DoNothing\DoNothing.exe
FINISHED
Scroll down to just below
max.tisc
Post by max.tisc »
HI medelec35
thanks for the screenshoots, they allowed me to understand where I was wrong.
Thanks again
No problem, so long as it helped.
What was the issue in the end?
max.tisc
Post by max.tisc »
hi
the problem was that i was downloading and installing visual studio community not build tools
thanks
