ESP32 How to set Power Level Bluetooth Classic BR/EDR
Has thanked: 246 times
Been thanked: 258 times
For the Bluetooth Classic BR/EDR it's possible to set the transmit power Level
mostly the transmission power can be adjusted in few steps dbm like
0dbm
+4dbm
+20dbm
With this setting you can set the distance range and the power requirement.
In my project I only need a few centimeters but I have a small battery available
Can I use commans to set or read like in this doku with flowcode?
https://docs.espressif.com/projects/esp ... ower_level
Has thanked: 177 times
Been thanked: 1026 times
Re: ESP32 How to set Power Level Bluetooth Classic BR/EDR
Post by mnfisher »
Should be possible in a C block - might need an include for the appropriate header file too (in supplementary code or just in main depending on use)
Hi Martin
I found 3 of this file and I included one of them (I have a ESP32 Pico)
No Error
#include "C:\Users\Kfs-Forschung\Desktop\esp-idf\components\bt\include\esp32\include\esp_bt.h"
I also build a variable ESP_ERR_ T (byte) and add the C code in my program. But now Error on compiling...
  Enter C code below this comment
FCV_ESP_ERR_T esp_bredr_tx_power_set(esp_power_level_tmin_power_level, esp_power_level_tmax_power_level)
File avaible
LeighM
Has thanked: 110 times
Been thanked: 302 times
Post by LeighM »
Hi Stefan
In your C code icon, you don't need the FCV_ESP_ERR_T so can remove it.
Also you do need a semicolon at the end of that statement.
Hope that helps
Hi Martin, Hi Leigh
I've tried many things but as soon as I activate the C code I can't compile anymore.
And I also suspect the path for the additional code would have to be shorter than what I did.
Demodata_ESP32_v2.fcfx
(87.52 KiB) Downloaded 605 times
Hi Martin, Hi Leigh
I tried the program from Martin to let the esp32 sleep.
After I change some paths then it working very nice.
Instead of 70mA it only needs 20mA (with a LED on) in sleep mode
https://flowcode.co.uk/forums/viewtopic ... 5660#p5660
I did the same for my program for the BT command
Also my command for BT Power dont give errors anymore.
But the power with bluetooth sending dont change even if I set to min or max power.
I'll see what else I need to do then additionally so the powermode will work.
esp_bredr_tx_power_set(ESP_PWR_LVL_N12,ESP_PWR_LVL_N9);
esp_bredr_tx_power_set(ESP_PWR_LVL_P6,ESP_PWR_LVL_P9);
Has thanked: 647 times
Been thanked: 856 times
Hi Stefan,
The Bluetooth transmission will essentially be a spike in the power of the module. Is your current monitor capable of detecting the spike or is it simply averaging? Even if you are constantly transmitting this might help to allow you to see the current usage a bit better but even then the radio tx packets will be sent in bursts and so may be being averaged out. There could also be capacitors on the module that are also somewhat shielding you from the spiked tx power usage.
A better test might be to charge a battery up to a known voltage and then time how long it takes to discharge to a known voltage. Then compare with a different BT power level.
Yes. Good idea. I will do that. I need the measurement anyway how long can I measure or send BT with one charge.
I understood now a little how use set commands for the ESP32
Can you also give me an example of how I can read values from ESP32 with FC9 "C command"?
Like this get command..
esp_err_tesp_bredr_tx_power_get(esp_power_level_t *min_power_level, esp_power_level_t *max_power_level)
https://docs.espressif.com/projects/esp ... _vhci.html
The C code for that might look like this. You can use a Flowcode Byte variables min and max to take the values in a more normal numeric format you can work with.
esp_power_level_t esp_min, esp_max;
esp_bredr_tx_power_get(*esp_min, *esp_max);
FCV_MIN = (unsigned char) esp_min;
FCV_MAX = (unsigned char) esp_max;
This is the breakdown for the power level values.
typedef enum {
    ESP_PWR_LVL_N12 = 0,                /*!< Corresponding to -12dbm */
    ESP_PWR_LVL_N9  = 1,                /*!< Corresponding to  -9dbm */
    ESP_PWR_LVL_N6  = 2,                /*!< Corresponding to  -6dbm */
    ESP_PWR_LVL_N3  = 3,                /*!< Corresponding to  -3dbm */
    ESP_PWR_LVL_N0  = 4,                /*!< Corresponding to   0dbm */
    ESP_PWR_LVL_P3  = 5,                /*!< Corresponding to  +3dbm */
    ESP_PWR_LVL_P6  = 6,                /*!< Corresponding to  +6dbm */
    ESP_PWR_LVL_P9  = 7,                /*!< Corresponding to  +9dbm */
    ESP_PWR_LVL_N14 = ESP_PWR_LVL_N12,  /*!< Backward compatibility! Setting to -14dbm will actually result to -12dbm */
    ESP_PWR_LVL_N11 = ESP_PWR_LVL_N9,   /*!< Backward compatibility! Setting to -11dbm will actually result to  -9dbm */
    ESP_PWR_LVL_N8  = ESP_PWR_LVL_N6,   /*!< Backward compatibility! Setting to  -8dbm will actually result to  -6dbm */
    ESP_PWR_LVL_N5  = ESP_PWR_LVL_N3,   /*!< Backward compatibility! Setting to  -5dbm will actually result to  -3dbm */
    ESP_PWR_LVL_N2  = ESP_PWR_LVL_N0,   /*!< Backward compatibility! Setting to  -2dbm will actually result to   0dbm */
    ESP_PWR_LVL_P1  = ESP_PWR_LVL_P3,   /*!< Backward compatibility! Setting to  +1dbm will actually result to  +3dbm */
    ESP_PWR_LVL_P4  = ESP_PWR_LVL_P6,   /*!< Backward compatibility! Setting to  +4dbm will actually result to  +6dbm */
    ESP_PWR_LVL_P7  = ESP_PWR_LVL_P9,   /*!< Backward compatibility! Setting to  +7dbm will actually result to  +9dbm */
} esp_power_level_t;
As soon as I use the get command I always get an error no matter what I try
Demodata_ESP32_post1.fcfx
(64.57 KiB) Downloaded 699 times
