ESP32 Compiling error
Has thanked: 245 times
Been thanked: 257 times
Re: ESP32 Compiling error
Hi Jollybv
I uninstall every thing and install it again
I have load it into just the ESP-IDF folder and it's not working
jollybv
Has thanked: 42 times
Been thanked: 15 times
Post by jollybv »
Hi Guys
I changed my display to gLCD ili9341 and updated all the components macro's deleted the old display, now I am getting error when compiling not sure if the gLCD component is clashing with the esp32 node mcu as I have not changed any code only updated from ST7735 to ili9341 and the code is working on ST7735 display
Error code display.txt
(12.42 KiB) Downloaded 768 times
jollybv
Post by jollybv »
Hi Guys
I have made a simple program just to test the ili9341 display by itself but it still dose not compile, I get
Error: Invalid value for '-b' / '--baud': 'flash' is not a valid integer.
Programming Failed
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_prog.bat reported error code 0x1
Autoclose turned off
I can run it in simulation but not on the board
Test_ili9341_display.fcfx
(12.41 KiB) Downloaded 625 times
Has thanked: 177 times
Been thanked: 1016 times
Post by mnfisher »
The error message means that the programming port isn't set (program options - bottom right)
jollybv
Post by jollybv »
Thanks Martin something simple
jollybv
Post by jollybv »
Hi Guys
Can someone please explain why my program will not compile with the ili9341. The first message i get is as follows
error 1.txt
(63.36 KiB) Downloaded 805 times
If i try to compile a second time then i get this message
error 2.txt
(63.36 KiB) Downloaded 886 times
Brew_controller_ili9341.fcfx
(149.06 KiB) Downloaded 876 times
Hi Jollybv
I can compile it....
jollybv
Post by jollybv »
Hi Stefan
Thanks any idea why it wont compile on my machine? I have uninstalled Flowcode reinstalled still not compiling I have also reactivated flowcode licence nothing, this is driving me nuts anyone got any good suggestions on how to sort this.
LeighM
Has thanked: 107 times
Been thanked: 302 times
Post by LeighM »
Builds for me too.
I notice this in the error2.txt ...
CMake Warning in ../../bootloader_support/CMakeLists.txt:
The object file directory
C:/Users/brian/Dropbox/Designs_and_software/Boards-21-04-14/Boards_In_the_market/PWM_Controller/Test_gLCD_ili9341/Brew_controller_ili9341/build/bootloader/esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/
has 222 characters. The maximum full path to an object file is 250
characters (see CMAKE_OBJECT_PATH_MAX). Object file
src/bootloader_common_loader.c.obj
cannot be safely placed under this directory. The build may not work
correctly.
I suggest that you copy your project to a shorter path and try again.
jollybv
Post by jollybv »
Hi Leigh
Thanks for that it has solved the problem and I have learnt something new, maybe that is why I have had to save my projects 2 or 3 times before it will compile (path to long)
