DC Motors
fwall
DC Motors
Post by fwall »
Hi there,
I am trying to use the DC motor component in my code and I need it to move for 10 seconds. I have tried using the component macros forwards(10) and coast but is seeming to stop early, of if I use forwards(1) it won't stop! Would greatly appreciate if someone could explain how they function and how I can best code them to rotate forwards for 10 seconds and also backwards for 10 seconds. I can't find much online.
Thanks in advance
Has thanked: 551 times
Been thanked: 735 times
Re: DC Motors
The number assigned is the speed when using PWM or HBRIDGE control method. For simple on/off the number will make no difference.
Sounds like your program needs to do the following.
Forwards (1)
Delay S (10)
Stop ()
You might need a further delay at the end, if you're inside a loop with no delay at the end then we will go straight back into Forward which will appear like the Stop function never got called.
Hope this helps.
Has thanked: 685 times
Been thanked: 759 times
Re: DC Motors
Hi.
If you are interested, I posted an example on this post.
Has thanked: 404 times
Been thanked: 624 times
Re: DC Motors
Post by chipfryer27 »
Have you looked at the component example yet?
https://www.flowcode.co.uk/wiki/index.p ... C_Motor_()
How are you connecting your motor? The example is for a Full-Bridge config. If you can share your flowchart and how you are connecting (even if just simulation) I'm sure the forum can assist.
Edit...
Seems Ben and Medelec beat me to posting <s> Generally speaking, always do as they suggest :)
PD1404
Re: DC Motors
Post by PD1404 »
When I use a program as mentioned by others. I am getting a message as 'one or more pins of component motor-full bridge 2 are not connected to the microcontroller.
Can anyone tell me what I have to do to rectify this issue.
DCmotor not working.docx
(75.12 KiB) Downloaded 558 times
Has thanked: 247 times
Been thanked: 402 times
Re: DC Motors
Right-click the motor component and select "properties". Then in the Properties window make sure any pin connections are correct. Each one will either start with a "$" or be labelled as "Unconnected". Ensure that all of these are correctly assigned to a valid pin for your microcontroller by clicking on the port/pin value (or the "unconnected" text) in the right column of the property list.
