RPI PICO SPI problem
max.tisc
Been thanked: 10 times
Post by max.tisc »
hi team
I have a problem with the SPI component, using it with RPI PICO the compiler gives an error, the component had been changed recently the prescaler frequency setting I am attaching the compiler files
thank you
PICOTT.msg.txt
(5.8 KiB) Downloaded 460 times
Has thanked: 510 times
Been thanked: 700 times
Re: RPI PICO SPI problem
Please can you post your .fcfx project file and we will investigate for you.
max.tisc
Post by max.tisc »
hello BenR
I am sending you part of the project
thank you
PICOTT-test-spi.fcfx
(110.02 KiB) Downloaded 509 times
Many thanks for letting us know.
That should be sorted for you now via the Help -> Library updates.
Please let us know if you have any additional problems.
max.tisc
Post by max.tisc »
thanks BenR
I have tested the SPI modification and I would say that it works, but I think I will go back to the old and loved mega2560 because it seems to me that the rpy pico is not yet well developed and many other things do not work, I would be tempted to try with the blackpill that mounts STM32F411 and see if it works better than pico
thank you
Can you say what you have found that isn't working well with the Pico and we can investigate. If we don't know about the problems then we can't fix them.
I must admit I personally don't see the appeal of the Pico when compared to say the ESP32 which brings wifi and bluetooth out the box, however a lot of people seem to love it so it's certainly worth us doing a good job with it.
kersing
Has thanked: 79 times
Been thanked: 64 times
Post by kersing »
The newest generation RPi modules has WiFi as well and Bluetooth will probably arrive as well…
https://shop.pimoroni.com/products/rasp ... 9369619539
Thanks Jac,
That certainly makes them more interesting, looks like there not available yet, I'll see if I can get my hands on one when they launch.
LeighM
Has thanked: 84 times
Been thanked: 263 times
Post by LeighM »
They were in stock last week, browsing on holiday, wish I'd bought one when I had chance, DOH!
