hi team
I have a problem with the SPI component, using it with RPI PICO the compiler gives an error, the component had been changed recently the prescaler frequency setting I am attaching the compiler files
thank you
RPI PICO SPI problem
max.tisc
- Been thanked: 12 times
- Has thanked: 607 times
- Been thanked: 803 times
Re: RPI PICO SPI problem
Please can you post your .fcfx project file and we will investigate for you.
hello BenR
I am sending you part of the project
thank you
thank you
- PICOTT-test-spi.fcfx
- (110.02 KiB) Downloaded 601 times
Many thanks for letting us know.
That should be sorted for you now via the Help -> Library updates.
Please let us know if you have any additional problems.
thanks BenR
I have tested the SPI modification and I would say that it works, but I think I will go back to the old and loved mega2560 because it seems to me that the rpy pico is not yet well developed and many other things do not work, I would be tempted to try with the blackpill that mounts STM32F411 and see if it works better than pico
thank you
thank you
Can you say what you have found that isn't working well with the Pico and we can investigate. If we don't know about the problems then we can't fix them.
I must admit I personally don't see the appeal of the Pico when compared to say the ESP32 which brings wifi and bluetooth out the box, however a lot of people seem to love it so it's certainly worth us doing a good job with it.
kersing
- Has thanked: 81 times
- Been thanked: 65 times
Hi Ben,
The newest generation RPi modules has WiFi as well and Bluetooth will probably arrive as well…
https://shop.pimoroni.com/products/rasp ... 9369619539
Thanks Jac,
That certainly makes them more interesting, looks like there not available yet, I'll see if I can get my hands on one when they launch.
