Floats as "number font" on display
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
The display fonts in the display components have a few fonts that only show numbers.
Is it possible to add a comma or a point to these "number fonts" so they could show a float-like number?
Thanks..
Has thanked: 647 times
Been thanked: 856 times
Re: Floats as "number font" on display
The Calibri Black Number and Fixed Number fonts include ASCII 43 to ASCII 58 and so should allow you , and . characters, looks like it's just the Verdana Number font that's more limited at ASCII 48 to ASCII 58.
I'll have a look and see how easy it would be to add the extra characters
I've had a go and pushed a new version of the font component to the library update system, hopefully Verdana Number should now have all the characters shown above to match the other Number fonts.
MJU20
Post by MJU20 »
Thanks BenR!
How can I print a number like 20.4 to the display?
Do I need to cut the 20 and the 4 and add a comma between them?
Then I need to calculate the position for the comma?
Or is there a better trick?
Now I use the printnumber macro for the SSD1306 OLED. But I I use a number like 20.4 it isn't displayed.
You should be able to use the float to string function in the calculation icon. The parameters are the floating point number , the number of decimal places.
E.g.
Str = floattostring$(float, 1)
Then print out the str as you would normally print out a string.
Let us know how you get on.
MJU20
Post by MJU20 »
Great BenR :D
This works!
But for me this is very confusing..
If you don't know this trick I wouldn't be able to figure this out.
A font, special for numbers, that uses a string to show a few characters...
Why not build this feature in the print number feature of the component?
But, thanks again for pointing me to this workaround.
Print number should also work fine but only works with integer numbers. I could maybe look at adding a print float macro to the graphical displays like we have for the alphanumeric displays.
