Do you have any news?
DSP FIR filter component coefficients
Oscar_T
- Has thanked: 37 times
- Been thanked: 10 times
- Has thanked: 616 times
- Been thanked: 814 times
Re: DSP FIR filter component coefficients
Sorry it's on the list, I looked at the example code you sent and it looks like they have done a lot of the DMA work themselves so maybe it's not as simple as the Espressif library makes out at the moment. I'll hopefully get back on with it soon but in the mean time if you fancy having a play then the C code for the I2S CAL can be found here.
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_I2S.c
Let me know if you have a go
Oscar_T
I think dma management can solve the problems but managing them correctly isn't easy .I will continue to investigate a bit and do some experiments.
Maybe I can find some code with comments that can actually understand how to properly handle i2s
Oscar_T
On the website of espressif is present "Espressif Audio Development Framework" whose examples are much more complete.
In addition, there are many examples https://github.com/espressif/esp-adf/tr ... e_passthru
I don't know, given the framework dedicated exclusively to audio if this can be integrated or not. But if you think it's a good way I couldgrab a couple of ESP32-LyraT Development Boards and send you one if that helps
I have been playing with i2s and have got output streaming working great. Trying to wrangle input streaming now but it's proving tricky. I'll keep at it and hopefully have it sorted this week with some easy to follow examples.
Here you go
