Most PIC micros have 1 DAC which has an output on pin A2 which is what the flowcode component is setup for.
the dac output can also be set to output on B7 instead of A2. see attached text from datasheet
is it possible to change the internal dac component to allow selection of A2 or B7 as I use port A as inputs
PIC Internal DAC output pin
Maverick
- Has thanked: 27 times
- Been thanked: 8 times
- Has thanked: 616 times
- Been thanked: 815 times
Re: PIC Internal DAC output pin
What device are you using and I'll investigate for you.
I've now added the alt DAC pins on the devices you mentioned. Updates should now be available via the library update system.
Please let me know how you get on and if you spot any further devices that need this mod.
Hi Gavin,
That's been done for you now, thanks for letting us know.
