Is there a way you can read the value of a port bit using a variable name to select the port bit used.
input port bit slect using variable name
Maverick
- Has thanked: 27 times
- Been thanked: 8 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: input port bit slect using variable name
The easiest way would be to use the switch icon.
Then you can add any input on any branch.
If for example, the value of the switch variable is 2 the branch which has 2 will be accessed.
That could have an input A2 for example
- Has thanked: 163 times
- Been thanked: 960 times
An alternative technique...
Read the entire port and then shift to get the required bit..
Have something like:
Where .n is the variable holding the bit you want to read and .p is a variable as 'wide' as the port (so byte for 8 bits or long for esp32 (32 bits port)).
.p = Input() // Read the whole port - click on Advanced options to allow this.
.bit = (.p >> .n) & 1 // Extract the required bit.
