DSP Components - An introduction
Has thanked: 645 times
Been thanked: 855 times
Here is a short video I made on how to use the DSP components in Flowcode. They should work equally well in Embedded or App Creator.
As always if you have any comments, questions or requests then please let us know.
DSP.fcfx
(16.75 KiB) Downloaded 730 times
ruben123
Has thanked: 6 times
Been thanked: 3 times
Re: DSP Components - An introduction
Post by ruben123 »
hi
I'm traying to replicate the same thing with an arduino uno
but i get this error( see attachement)
what do i wrong?
kind regards
dsp.fcfx
(15.82 KiB) Downloaded 541 times
error
error
Please can you try going to Help -> Library Updates, Then change the Files in use setting at the bottom of the window to Full Database. This should download some new files and after reloading your project hopefully it will all compile ok for you now.
One thing I did notice is the DSPWaveGen componnent Calculate Data property is currently generating a compile error when set to Yes so I'm going to try and investigate this for you now. edit - this should also be fixed now too.
ruben123
Post by ruben123 »
everything works now thank you 8-)
Has thanked: 246 times
Been thanked: 257 times
In your video everything works so simply but..
I tried to control the DAC of the ESP32 with the DSP.
Even on the beginn with the setting of the interrupt is not clear to me how that works.
At the end there should be a sinus signal of about 1 kHz on the DAC output, so a 10 kHz interrupt frequency would be good.
And as soon as I turn on the interrupt, the program crashes
how to set to 10khz
Simple dsp function:
Demo_ESP32_Key_post_DSP_out.fcfx
(75.85 KiB) Downloaded 535 times
