Hi Mm!
Please have a look here: https://www.flowcode.co.uk/mmforums/view ... 76&t=22510
Br Jorgen
Bugs!
jgu1
- Has thanked: 871 times
- Been thanked: 212 times
Re: Bugs!
Hello!
Still not possible to upload to 8bit Pic. No error or warning. Look like there no connection to EB board?
Br jorgen
Br jorgen
- Pic Om XC Comp.fcfx
- (7.67 KiB) Downloaded 870 times
- Has thanked: 300 times
- Been thanked: 465 times
Re: Bugs!
If no connection tot he EB board, have the drivers been installed ok? Are you able to program to the board on that PC with an earlier version of Flowcode?
Please post the project's "msg.txt" file here so we can see what is being reported by the toolchain and investigate further.
jgu1
Re: Bugs!
Hi!
No probs with FC8, still work. But I see in the view compileroption it call Picit2 Do I have to click to EB board, and is there any risk, or shouild it do this automaticly?
Br Jorgen
Br Jorgen
- Wiev Compilation.PNG (38.31 KiB) Viewed 19149 times
- Config.PNG (171.07 KiB) Viewed 19149 times
- Comp Option.PNG (60.16 KiB) Viewed 19149 times
Re: Bugs!
I did find an old post that said pk2cmd.exe does not like spaces within the file name of the hex file. Try saving your project with a short name without spaces and try again.
If that also fails, please post the "msg.txt" file for the v8 project that does download correctly.
Also, which E-blocks board are you trying to upload to?
jgu1
Re: Bugs!
Hi Steve!
Sorry no, short name withouth spaces also not work.
I use EB-006-00-9 (GHOST)
The 876Test is FC8 and work.
- 876Test.msg.txt
- (1.98 KiB) Downloaded 892 times
Re: Bugs!
I see the problem. In v8, you were using mLoader but in v9 you have chosen PICkit2. Please select "E-blocks" and make that the default in the "Compiler Options" screen.
Re: Bugs!
Glad you're up and running, Jorgen. I don't think uploading time should have changed as it's still the same version of mLoader. Perhaps the compiled HEX file is larger.
