ESP32-S2 FCDX request
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Re: ESP32-S2 FCDX request
Post by Xbiotec »
dear Ben,
release/v5.0 installed
Should I test it on Flowcode or wait your next message?
Seb
Has thanked: 629 times
Been thanked: 836 times
Hi Seb,
It's not currently working due to the I/O problems I've discovered. I'll try and make more progress on this soon, hopefully tomorrow.
Xbiotec
Post by Xbiotec »
thx for your feedback.
Indeed, I did compilation test with V5.0 and failed.
However, install new a IDF version with command below is working well.
git fetch
git checkout release/v5.0
git pull
git submodule update -f --init --recursive
install.bat
idf_tools.py uninstall                          from esp-idf\tools\ directory
idf_tools.py uninstall --remove-archives        from esp-idf\tools\ directory   to remove also archives
idf_tools.py uninstall was not working for me because my directories are not same as yours
To switch back to 4.1 version,
First need to update Git because switch command was introduced in version 2.23 as an attempt to simplify the process.
git update-git-for-windows
Now the current git version is 2.39.0
then, like you said, following command can be used
git switch -f release/v4.1
git fetch
git checkout release/v4.1
git pull
install.bat
I did a lot of testing and compilation after reverting to version 4.1, it work very well to switch between versions.
like you said,
For existing projects you will have to remove the cache directory located in the same folder as the Flowcode project file to force a complete recompile.
To check idf,Git and python version
idf.py --version
git --version
python -–version
To check ESPTOOL version installed. Last version is 4.4
pip3 show esptool
Thx
Seb
Xbiotec
Post by Xbiotec »
hello Ben,
What are the news ?
Seb
Xbiotec
Post by Xbiotec »
still no news ?
Seb
Hi Seb,
Sorry I've been trying to get a few projects off my desk before the holidays, I started to look into this one and the IO problem currently has me stumped. We could just call the public IO functions but these were very slow compared with accessing the registers directly. Something in the IDF has changed to do with the IO registers and I don't want to go backwards in terms of speed/efficiency so I'll keep chipping away at it. Hopefully have more news for you shortly.
Xbiotec
Post by Xbiotec »
Thx for you answer Ben
Hope you will find a way ASAP after holidays !
Seb
I'll have another crack at this tomorrow, hopefully making some progress now but there's lots on atm so having to divide my time.
Xbiotec
Post by Xbiotec »
hello Ben,
what are the news and status ?
Seb
Hello Seb,
Sorry I've put this on hold for the moment as we are launching Flowcode v10 very soon and there are a few tasks that need to be completed. As soon as this is out the way I'll have some more time to properly investigate this for you.
