Ili9488 Print number string!
jgu1
Has thanked: 839 times
Been thanked: 205 times
Post by jgu1 »
Hi!
If I try to print a number (float) in the display I do not get any digit after the komma
The same if I try to convert from float to String and print the string.
same result if I read out the value Intgr and convert to string.
It work in LCD display.
Is there another way, please?
Br Jorgen
To str.PNG (29.8 KiB) Viewed 1802 times
NySolcelle.fcfx
(26.79 KiB) Downloaded 98 times
Has thanked: 292 times
Been thanked: 458 times
Re: Ili9488 Print number string!
The code in your "AMPS" macro appears to be working and the "Amps" float variable is correctly being converted to a string and being displayed on the LCD. But this macro is never called in your program.
If you run the "AMPS" macro directly (using the dropdown underneath the "run/go" button then you will see this macro working correctly.
Has thanked: 724 times
Been thanked: 783 times
Hi.
Have made some small changes for you.
If you convert an integer to a string there will only be whole numbers.
The format you need is MyString = FloatToString$ (MyFloat,x)
Where x = required number of decimal places.
50A Custom Component.png (10.64 KiB) Viewed 1797 times
As you can see, if you enter a minor and a major value, more numbers will appear on the component scale.
NySolcelle v2.fcfx
(27.08 KiB) Downloaded 97 times
jgu1
Post by jgu1 »
Hi Martin and Steve!
Ohh yes, now I see the ligth, and it work. Again thank´s to you both :D
Br Jorgen
