I can not run dfplayer. It do not work. What may be the reason?
DFPlayer problems
Sergejs
- Has thanked: 75 times
- Been thanked: 5 times
- Has thanked: 444 times
- Been thanked: 665 times
Re: DFPlayer problems
Can you be a bit more specific as to what isn't working? Posting your code would be helpful.
- Has thanked: 165 times
- Been thanked: 967 times
I've attached my dfplayer component and a simple demo that played some sounds....
Looking at it now - the sample is slightly odd - it had a very specific purpose - but it shows the necessary setup and how to play files (it was a MCU with several buttons attached and required to play different sounds on presses?)
To install the library to FC - put it in a directory and make global-options->locations->Look for components in point to the directory...
