DFPlayer problems
Sergejs
Has thanked: 75 times
Been thanked: 5 times
DFPlayer problems
Post by Sergejs »
I can not run dfplayer. It do not work. What may be the reason?
Has thanked: 444 times
Been thanked: 665 times
Re: DFPlayer problems
Can you be a bit more specific as to what isn't working? Posting your code would be helpful.
Has thanked: 165 times
Been thanked: 967 times
Post by mnfisher »
I've attached my dfplayer component and a simple demo that played some sounds....
DFPlayer.fcpx
(4.79 KiB) Downloaded 483 times
sound pic v8.fcfx
(11.97 KiB) Downloaded 538 times
Looking at it now - the sample is slightly odd - it had a very specific purpose - but it shows the necessary setup and how to play files (it was a MCU with several buttons attached and required to play different sounds on presses?)
To install the library to FC - put it in a directory and make global-options->locations->Look for components in point to the directory...
kaqkk007
Has thanked: 4 times
Been thanked: 4 times
Post by kaqkk007 »
I want to play a sound using Pic, I only have 1 button and the sound file is "saved" in folder 1 in field 0001
