display IlI9341
Osta
- Has thanked: 1 time
- Been thanked: 5 times
display IlI9341
I have a problem with the text output on the display IlI9341
- PROBA_FC9.fcfx
- prog
- (16.93 KiB) Downloaded 465 times
- (view online)
- proteus
- ILI9341.jpg (72.85 KiB) Viewed 5823 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: display IlI9341
Hello Osta,
Have you tried on the hardware to see if it does the same thing there?
Any you using the latest component updates using Help -> Check for updates menu?
I have a display here I can try if you're still getting the problem.
Re: display IlI9341
Hello Ben!!!
Now there is an opportunity to answer.
Yes, I always debug in the proteus and then in the gland.
Updated all libraries the result is the same
- iron
- bug.jpg (103.48 KiB) Viewed 5781 times
Re: display IlI9341
Took me a while but testing here and it's all working correctly. Have you used the Help -> Check for updates to ensure you are using the latest version of the component?
