App developer more Button
Oscar_T
Has thanked: 37 times
Been thanked: 10 times
Re: App developer more Button
Post by Oscar_T »
I have successfully implemented the keyboard controls, but I am unable to insert the mouse.
Every 100 ms of checking if the mouse is clicked, if so I go to read the coordinates.
Unfortunately, even if the mouse is clicked (which key), the value of the variable associated with the GETMOUSEBUTTONS macro does not change
Has thanked: 633 times
Been thanked: 837 times
What are you trying to do with the mouse and maybe I can help.
Flowcode has inbuilt functions to help deal with the mouse. Maybe I can create a video to help demonstrate how to use these. They work using events and so you wouldn't have to use polling.
Oscar_T
Post by Oscar_T »
i am trying to do the following
I have inserted some graphic symbols that correspond to a certain action.
If the user clicks on the area where the symbol is present, he will activate the associated function
I've created a new video here that should hopefully help you to get started.
viewtopic.php?f=6&t=188
Has thanked: 245 times
Been thanked: 256 times
I used a Switch Push Button in App developer some time ago. Now I would like to use this Switch Push Button again in another APP but I can no longer find this component. I renamed the handle but I should still find Switch Push Button as a component?
Switch Push Button
That looks like v10 and one of the new 2D only panels, which was the original switch you were using and was it an old 3D component?
On the Comp Libraries toolbar there is a 2D/3D filter at the left hand side, check this is set to showning all components.
The Search may also be also to show any components that have been dropped from the component categories. I am yet to re-organise the AppDeveloper cats for v10 so hopefully I can do this later this week.
