All Switchs not work
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 All Switchs not work
Post by niedian »
All
Switchs not work.jpg (110.94 KiB) Viewed 5100 times
niedian
ALL Switchs not work
Post by niedian »
ALL Switchs not work.The return value cannot be set.
All Switchs not work.fcfx
(10.08 KiB) Downloaded 507 times
niedian
All switches do nothing
Post by niedian »
All switches do nothing.
All switches do nothing.fcfx
(9.7 KiB) Downloaded 532 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: All switches do nothing
Post by p.erasmus »
Hi Please keep one forum post for your switch problem ,posting several most only cause confusion and does not help you getting support faster and secondly how do you think we should know what is your problem if you do not write and small text to explain your problem.
Has thanked: 647 times
Been thanked: 856 times
Thanks for letting us know.
I'm investigating the problem for you now, it seems to be something specific with the 3D panel.
For now while we solve the problem you could instead use the 2D components on one of the 2D panels.
Has thanked: 311 times
Been thanked: 479 times
As @p.erasmus said - please don't post the same topic multiple times. I have now merged these topics, but it wastes time that might be better spent investigating the issue.
We've investigated this issue and found the problem.
The problem occurs because target device you are using does not have a valid PORTA.0 pin and v10 now includes additional checks to ensure port and pins in calculations actually exist. Your project should work if you change the target to one with A0.
Unfortunately it seems the fix requires a new version of Flowcode and we can't simply issue a component fix via the library updates. This will take a little longer to do, but I hope we can have a fix within the next week or so.
In the meantime, please let us know if you find any other issues.
