How to know which modification are done on components?
Xbiotec
- Has thanked: 37 times
- Been thanked: 27 times
- Has thanked: 650 times
- Been thanked: 856 times
Re: How to know which modification are done on components?
What errors are you getting with the latest version?
I have removed the need for the supplementary code in the latest version so maybe that's causing the problem if the time variable is being declared twice?
Xbiotec
do I need to remove the complete code ?
#include "esp_sntp.h"
void time_sync_notification_cb(struct timeval *tv)
ESP_LOGI(TAG, "Notification of a time synchronization event");
time_t now;
struct tm timeinfo;Seb
Hi Seb,
Yes none of it should be required so you can try and comment it all out with some
code
Or simply uncheck the use supplementary code tickbox in the project options.
code
