ESP32 read i2c or i3c in IRQ macro
Has thanked: 177 times
Been thanked: 1026 times
Re: ESP32 read i2c or i3c in IRQ macro
Post by mnfisher »
Hi Stefan,
You need the TaskId from xTaskCreatePinnedToCore - to pass to notify..
I think it is the last but one parameter - and you'll need to pass the address of a FC variable..
So if the variable is SaveToSDTask (needs to be a UINT32) - then pass &FCV_SAVETOSDTASK - the 'drag' variable to the C block is good here....
& - gets the address..
If you use Notify to wake the task then it shouldn'tneed a delay....
Has thanked: 246 times
Been thanked: 258 times
Hi Martin
Yes I dont need a delay and there is no watchdog fired. Just change the command like this.
The cornumber needs to be on the end and the variable b4.
working program:
Uart_int.fcfx
(25.02 KiB) Downloaded 255 times
Post by mnfisher »
For interest - I wanted to see if the accelerometer is returning 'meaningful' data....
I added a 'SaveData' macro - although in this case it outputs the first 4 6 value samples from the save buffer to UART... I went with using accel_data[0..499] as buffer 0 and [500.999] as buffer 1.
The ReadSample macro - notifies the SaveData macro when a buffer is full.
The values change more dramatically when I move the sensor - but I'm not much the wiser?
lsdm3_int.fcfx
(27.54 KiB) Downloaded 222 times
Your IRQ handling is working fine. And reading faster I2C also!
I adjust for my hardware and let it run
If the sensor is flat on the table the z-axis has +16400 digit
If I turn it 90 deg an other axis goes to -16300 and z-axis goes to zero
so I turn 180 deg axis goes to goes to +16300
mod program to send String to uart
lsdm3_int4.fcfx
(31.81 KiB) Downloaded 225 times
Post by mnfisher »
Thanks Stefan,
That's very helpful - I'll have a look and see if I can spot the pattern in my sensor's returns.
Post by mnfisher »
Just tested - and yes. The results look sensible...
Saving buffer 0 - (182,1678,-16281)
Saving buffer 1 - (154,652,-15675)
Saving buffer 0 - (-16348,436,500)
Saving buffer 1 - (-16326,482,950)
Saving buffer 0 - (-34,16344,-922)
Saving buffer 1 - (2,16330,-965)
With the board 'aligned' in each of the 3 planes. I set the delay between samples to 10ms - to allow a more sedate update rate...
Hi Martin
Your program works fine even if I add some more commands
lsdm3_int4.fcfx
(38.56 KiB) Downloaded 268 times
My program give a watchdog error if I write to I2C even in at loop an begin
IMU_POST_sd_card_wave.fcfx
(282.82 KiB) Downloaded 280 times
Post by mnfisher »
Hi Stefan
Not entirely sure why the wdt is getting fired - but in main() - you have a loop
Oops - sorry a bit larger than expected!
Which doesn't exit - is this intended? It has a delay - so wouldn't expect the wdt issue though (although the program won't progress?)
Post by mnfisher »
I notice a slight oddity. The Enable timer interrupt - describes microseconds support as 'experimental'.
However the code generated is (for example):
      // 60 HZ (16mSec)  62.5Hz
      FC_CAL_Timer_Period = 16;
      FC_CAL_Timer_Multiplier = 1000;
      FC_CAL_Timer_Init(0, FC_CAL_Timer_Period * FC_CAL_Timer_Multiplier, FC_CAL_Timer_0_ISR);
i.e - all the timer interrupts actually use microsecond delays (and to test - setting a timer to 10s -> 10 x 1000000 as the delay).
So - I'd question the 'experimental' - it might also be worth checking if there are more efficient options for longer delays.
It might not actually check every microsecond (RTOS might optimise this?)
It also gives the chance to use a calculation to calculate the delay:
.tDelay = 1000000 / frequency_in_Hz
and then in a code block:
FC_CAL_Timer_Init(0, FCL_TDELAY, FC_CAL_Timer_0_ISR);
It also means that using milliseconds isn't necessary (there is no advantage to doing so) - so in the above example - a much closer approximation to 60Hz could be generated using 16666 us as the timer length.
Post by mnfisher »
Just tested - and it does work as expected :-)
As pointed out previously - I don't think stopping / restarting interrupts works. The esp timer handlers do allow this (with things like one_shot and periodical timers) - and also allow multiple 'interrupts' (or callbacks) per timer.
A very simple example that allows a pin to be toggled at a given rate - it doesn't handle rates slower than 1Hz (every 10s say) - but it could be handled with some simple changes.
Setting the divider on the timer would be the answer for lower frequencies.
tmr_test.fcfx
(12.79 KiB) Downloaded 207 times
