Something awry with v10....
So - I re-exported from v10 and it still crashed - send report bad crash...
I re-exported again and still no joy. So I tried adding another component - first that I tried failed (unable to add) - second (picked at random - grove_humidity_sht31) added okay... Then I could add the display component - and compiles okay. Also runs okay in sim. I could also delete the grove component (although still in the file here)
MAX7219 32x32 LED Display
- Has thanked: 177 times
- Been thanked: 1027 times
Re: MAX7219 32x32 LED Display
- Display4x4Max7219.fcpx
- (4.85 KiB) Downloaded 2197 times
- led_test2.fcfx
- (8.99 KiB) Downloaded 2209 times
- (view online)
- Has thanked: 312 times
- Been thanked: 480 times
Thanks. I will have a look to see if I can determine why this component is causing a crash.
kaqkk007 - phew... Lets us know how you get on!
Steve - thanks, I might have done something odd?
What would you like to do?
I had a fairly specific need (points and numbers) when I wrote it - but it could be extended fairly easily?
The LUT contains 16*16bit maps for 0..9. I got AI to draw the characters with limited success
The LUT could be the extended to include other characters (either text or graphic) if needed (for example set char 10 to be ':' for your clock?) or go the whole way and use ASCII?
As far as I'm concerned, there's no reason why we couldn't use ASCII characters—or even write a LUT—if a "mere mortal" could access it. The only thing missing from our repertoire is the display itself. https://www.youtube.com/channel/UCanvQp ... LOj5nXYJ2Q
As another thought - it would be easy to add a DrawChar macro that takes an array of data - so the client program would store it's own data. This could work with 16*16 (as Write) or possibly 8x8?
