HMC5883L Bug or me!
Has thanked: 713 times
Been thanked: 775 times
Re: HMC5883L Bug or me!
I have attached the basic test file I used.
You will need to add your backpack LCD component, so Flowcode knows the component you want to use, then delete it.
Right-click on the LCD that is currently on the 2D panel and select Replace....
The LCD will then be replaced with backpack version.
HMC5883L test.fcfx
(13.92 KiB) Downloaded 124 times
Has thanked: 829 times
Been thanked: 204 times
Post by jgu1 »
Hi Martin!
Perfect, now the HMC5883 work with your examble (think you have made it in FC11 Created in a newer version, work in FC10) now I can go on with my project.
I will check the QMC later with your examble, of course change the device. Futhermore, I laern to change display /component fast and easy also, very smart.
Thank you very much Martin for your job, have a nice weekend, 10 stars again to you :D
Jorgen
Aww, thanks Jorgen.
You're welcome.
I love it when get awarded 10 stars.
I glad you can get on with your project.
You too have a nice weekend.
Flowcode v10 Re: HMC5883L Bug or me!
Post by jgu1 »
Hi MArtin!
When will you push the correction to update, pls.
Jorgen
Hi Jorgen.
The component has been pushed to component library updates.
Post by jgu1 »
I see Martin, thank you :D
