ESP32 UART-USB Brige How to use
Has thanked: 245 times
Been thanked: 256 times
Re: ESP32 UART-USB Brige How to use
Hi Martin
My testprogram:
Adafruit_5691_01_fc11_19.fcfx
(66.15 KiB) Downloaded 482 times
You can find a description of the hardware here
viewtopic.php?t=3644
Hi Martin
One a question:
There is still one entry missing :
CONFIG_USB_DEVICE_ENABLED=y
CONFIG_TINYUSB_ENABLED=y
CONFIG_TINYUSB_DEVICE_ENABLED=y
CONFIG_TINYUSB_CDC_ENABLED=y
in the file:
sdkconfig.defaults.esp32s3
But in FC11 there are so many sdkconfig.defaults.esp32s3.
Which one is the right one?
Hi Martin
I've now updated to 5.3.1 and added the USB Tiny dependency.
I also have some C code there can I use it in Flowcode?
include are ok:
#include "tinyusb.h"
#include "tusb_cdc_acm.h"
#include "esp_log.h"
C-Code for USB:
void app_main(void)
    // TinyUSB Basisconfig
    tinyusb_config_t tusb_cfg = {
        .device_descriptor = NULL,
        .string_descriptor = NULL,
        .external_phy = false       // intern USB-PHY des ESP32-S3
    // USB-Device (TinyUSB) start
    tinyusb_driver_install(&tusb_cfg);
    // USB-CDC (virtueller COM-Port) config
    tinyusb_cdcacm_config_t cdc_cfg = {
        .usb_dev = TINYUSB_USBDEV_0,
        .cdc_port = TINYUSB_CDC_ACM_0,
        .rx_unread_size = 64,
    tusb_cdc_acm_init(&cdc_cfg);
    // wait, for USB clean
    vTaskDelay(pdMS_TO_TICKS(300));
    // „Hello world“ send
    const char *msg = "Hello world\r\n";
    tusb_cdc_acm_write(TINYUSB_CDC_ACM_0, (uint8_t *)msg, strlen(msg));
    tusb_cdc_acm_write_flush(TINYUSB_CDC_ACM_0, 0);
    //  (Flowcode need main loop)
    while (1)
        vTaskDelay(pdMS_TO_TICKS(1000));
Has thanked: 173 times
Been thanked: 989 times
Post by mnfisher »
Hi Stefan,
Yes - you can use the C to initialise - rename (app_main) initialise (or some such) and add a function definition to the 'includes' (top) box of supplementary code... ( void initialise(void); ) Remove the loop (and the 'hello world'?) from the end of the function...
Then call initialise(); from a C block.
You can also add a 'Print(char *str);' function - which could call tusb_cdc_acm_write and flush..
Hi Martin
Thank you Martin I'll give that a try.
I've had a bit of success with `print_F` so far.
I still have no idea how to send an array
Very short program:
Post_esp531_1.fcfx
(9.77 KiB) Downloaded 493 times
C-Code:
On computer (regardless of the baud rate)
Hi Martin
Your suggestion works perfectly!
I had to make a few adjustments. Sending is done using the function in the additional code. How can I send an array from my program? I'm not sure exactly where I need to add FCV_.
Post_esp531_3.fcfx
(13.91 KiB) Downloaded 447 times
Post by mnfisher »
Hi Stefan,
Something like this?
Post_esp531_3.fcfx
(12.4 KiB) Downloaded 437 times
However - I have some serious issues recompiling this (- a nested #include somewhere!) - I removed the UART component thinking it was this (and I had a seemingly unending circular list of errors!) - but I still get "
from C:\Users\Martin\Downloads\tinyusb.h:66,
from C:\Users\Martin\Downloads\tinyusb.h:66"
A couple of hundred times :-(
However - if you can get it to compile - it should work.... I added a 'Print' macro to allow output to be made a little more 'flowcode'
Will have to fiddle a bit and find out what's gone wrong with my setup :-(
Post by mnfisher »
I commented out a couple of the #includes in supplementary code - you'll probably need to re-enable....
Hi Martin
Your program is working fine
Maybe You need ESP-IDF 5.3.1
and in the menuconfig batch file
this line ....
python "C:\Users\Kfs-Forschung\Desktop\esp-idf-2\tools\idf.py" add-dependency esp_tinyusb
Hi Martin
I expanded your example to include an array for sending data, and it works.
I can also receive the binary data array very easily using the Flowcode APP Developer. :)
Demo:
Post_esp531_4.fcfx
(13.77 KiB) Downloaded 492 times
