ESP32 Atom Matrix, Pin not as an input
Has thanked: 246 times
Been thanked: 258 times
I'm using a board that works well with Flowcode.
Led Matrix, Uart, USB and Bluetooth are fine.
Flowcode with this board is fun!!
The button is the only problem.
When you press on the LED display, a button closes. This is on port G39.
However, this port G39 does not work with FC9 as an input.
I tested all external ports from this board:
The following ports work as an input
G21,G23
The following ports do not work as an input
G39,G33,G19,G22,G25
Is there a possibility that these ports work?
