PIC16(L)F18446.fcdx with wrong definitions (continuation)
miggarc
Has thanked: 7 times
Been thanked: 4 times
Post by miggarc »
On May 31, 2022 10:38 pm I posted a bug report named
PIC16(L)F18446.fcdx with wrong definitions .
You promptly solved this uC definitions and all compile well.
The problem is, even with an absolute simple flowchart like this
timer 2 is still not working.
It simulates as if all is correct (functioning as expected) but, after compiled (no errors)
and transfered to the real PIC16LF18446 it doesn't work
If you could look at this before we enter the weekend I will appreciate it very much.
Many thanks in advance,
Miguel Garcia,
Electronic Systems Developer
Has thanked: 311 times
Been thanked: 479 times
Re: PIC16(L)F18466.fcdx with wrong definitions (continuation)
I don't have any hardware to test and I'm not familiar with that particular chip, but try putting the following statements into a C icon just before you enable the interrupt:
T2CLKCONbits.CS = 2;
T2HLTbits.MODE = 0;
The first statement ensures the clock source is the main Fosc clock rather that whatever is set in the PPS (Peripheral Pin Select).
miggarc
Re: PIC16(L)F18446.fcdx with wrong definitions (continuation)
Post by miggarc »
Hi Steve
Your cue did the trick .
How do I mark this as solved ?
Miguel Garcia,
Great news, thanks. I'll ask for the fix to be added to the chip definition file.
I think to mark it as solved you can edit your original post and change the subject line, e.g. by adding "[SOLVED]" to the end of it.
miggarc
Post by miggarc »
Hi...
I was thinking about marking this topic as Solved but, at the very last moment before I did it, another related problem arose:
I found result frequency doesn't change with different options from Clock Source Select ,
at least for any PIC16LF18446 timer interrupt properties where this drop down exists: TMR0, 1,3 and 5 .
Some examples ...
Miguel Garcia,
We are aware of this issue. Please see here:
viewtopic.php?f=5&t=1231&p=6844#p6844
