all eeprom component Compilation failure
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 all eeprom component Compilation failure
Post by niedian »
all eeprom component Compilation failure.why?
serial_24c16 Compilation failure.jpg (16.94 KiB) Viewed 2529 times
serial_24c16.fcfx
(9.17 KiB) Downloaded 438 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: all eeprom component Compilation failure
Post by p.erasmus »
I told you once before use the help wiki when working with components !
If you do not connect the pin properies of the component the code will not compile
I connected the eeprom to mcu pins in your FC chart and it compiles fine for me
:D
niedian
Post by niedian »
Thank you very much
