atmega 2560 flowcode9 does not work
d820513
Has thanked: 2 times
Post by d820513 »
today switched to atmega 2560, uploaded blink, but it doesn't work via flowcode
atmega2560_blink.fcfx
(6.89 KiB) Downloaded 708 times
Has thanked: 302 times
Been thanked: 471 times
Re: atmega 2560 flowcode9 does not work
Is this an issue with simulation or downloaded code, or both?
d820513
Post by d820513 »
uploaded blink
Are the configuration options in "Build..Project Options" appropriate for your hardware? Specifically the clock source.
d820513
Post by d820513 »
yes, I checked it several times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Flowcode v9 Re: atmega 2560 flowcode9 does not work
Post by p.erasmus »
Running your flowchard on a Adruino Mega2560 the code is working fine ,I susspect your Configuration settings for your mega is not set correctly as Steve indicated above
d820513
Post by d820513 »
where can i see the settings? can i reinstall flowcode9
p.erasmus
Post by p.erasmus »
Why do you want to reinstall FC9 ,what Hardware are you using a custom build or an Arduino board?
Go to Build Project options as below
Then theconfiguration window opens you have to set the Configuration of the Mega to suit your hardware configuration
d820513
Post by d820513 »
ok i will do as you said
d820513
Post by d820513 »
look
2560mega options.jpg (31.46 KiB) Viewed 9062 times
