SD Card Component
Has thanked: 647 times
Been thanked: 856 times
SD Card Component
I have found and fixed a bug in the SD card component code that caused a problem when a file size was greater then 256 sectors in length (131,072 Bytes). Took quite a while to pin it down. I've now rolled this change out to V8, V9 and V10 components and is available via the usual library updates.
I also have sped things up considerably for ESP32 related devices. The SPI speed wasn't changing from the initial slow speed and the sector buffer was being read a byte at a time both of which were having an impact.
If anyone has a go with the latest component then please let me know how you're getting on just in case I've broken something elsewhere.
Has thanked: 246 times
Been thanked: 258 times
Re: SD Card Component
I will test it soon.
One more question
With uart and bluetooth you can easily transfer an array with a singed integer. An array can then be written to a file using the built-in function in the App developer (append)
Would that also be a possibility for the SD card to append an singed integer array?
Would be very convenient for data or wave files.
https://flowcode.co.uk/forums/viewtopic.php?f=4&t=1133
Hi Stefan,
Yes should be fairly easy to add read/write arrays to the component.
Let me have a look.
Edit. this is now done. Let me know how you get on, if it works ok I'll look at the AD version of the component too.
WingNut
Has thanked: 56 times
Been thanked: 43 times
Post by WingNut »
Would this fix potentially speed up writing to sd card with Pic micro?
WingNut wrote: ↑
Mon Mar 06, 2023 3:15 pm
Possibly, It certainly shouldn't hurt. Main thing to help get speed with the PIC would be to get the high speed SPI prescaler as low as you can and use a hardware based SPI channel.
WingNut
Post by WingNut »
Must have a play with that later
After the lib update with the FAT component I get a problem in compiling
Fc10_2023_emg_ekg__v_2023_03_02_11-00.msg.txt
(90 KiB) Downloaded 614 times
I tested Version 9 from the FAT component and this is working fine (version10 not)
I will still measure the improvement of the speed in the laboratory
6 Channel of 8Channel, 24bit, 80hz Signal sampled with PIC32 and saved to micro SD card
Hopefully solved for you now.
Yes it's fine now with the FAT component.
I tested this new version12
and the 80Hz signal sampled with 2kHz looks good even in the spectrum.
