ArduinoNano
Vatel20
Flowcode v9 ArduinoNano
Post by Vatel20 »
in Arduino NANO atmega328p the analog inputs ADC7, ADC6 can not be selected.
Has thanked: 645 times
Been thanked: 855 times
Re: ArduinoNano
Many thanks for letting us know. Hopefully the pins should be available now by downloading the latest updates using the Help -> Check for updates menu.
Vatel20
Re: ArduinoNano
Post by Vatel20 »
The problem has been fixed. Thanks
ruben123
Has thanked: 6 times
Been thanked: 3 times
Re: ArduinoNano
Post by ruben123 »
hello
The probleme still exist , tried updating no update's found
kind regards Ruben
led_test.fcfx
(15.02 KiB) Downloaded 445 times
Re: ArduinoNano
Pin ADC6 and ADC7 are analogue input pins only and cannot be used as digital pins. You should be able to use the pins with the ADC components such as the potentiometers and sliders.
