Req: NEC IR component
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
Strange that there isn't a NEC IR component already..
I saw some posts regarding the NEC protocol, but this doesn't seem to be a hard thing to add to FC as a component?
This is a capture of what my logic analyser detects from a cheap Chinese IR remote control.
NEC protocol.jpg (110.17 KiB) Viewed 8408 times
The protocol starts with a 9ms "0", followed by a 4.5ms "1". After that there is the low and high address byte, followed by the data, and the inverse data..
Could there be a component in the (near) future?
Has thanked: 177 times
Been thanked: 1026 times
Re: Req: NEC IR component
Post by mnfisher »
I did a bit of experimenting with this - didn't make it into a component though...
Try
NEC PIC2.fcfx
(23.33 KiB) Downloaded 808 times
Post by mnfisher »
Which is a PIC specific version also try:
NEC Own Timer (1).fcfx
(28.74 KiB) Downloaded 722 times
Which uses the timer component
MJU20
Post by MJU20 »
Thank you very much!
Need to investigate it somewhat deeper.
But a real Flowcode component is something that should be standard already?
I asked ChatGPT and this generates this C code :-)
Could this be something that could be converted into a component?
#include <stdio.h>
#define NEC_START_HIGH 9000
#define NEC_START_LOW 4500
#define NEC_BIT_HIGH 560
#define NEC_BIT_LOW_0 560
#define NEC_BIT_LOW_1 1690
void decodeNEC(unsigned int *data, int dataLength, unsigned char *result) {
    for (int i = 0; i < dataLength; i++) {
        unsigned int pulse = data[i];
        if (pulse >= NEC_BIT_LOW_1 / 2 && pulse <= NEC_BIT_HIGH + NEC_BIT_LOW_0 / 2) {
            // logische "1"
            *result |= (1 << (7 - (i % 8)));
        if (i % 8 == 7) {
            result++;
            *result = 0;
int main() {Hieronder staat een voorbeeldreeks van pulslengtes (vervang deze door je eigen gegevens)
    unsigned int data[] = {NEC_START_HIGH, NEC_START_LOW, NEC_BIT_HIGH, NEC_BIT_LOW_1, NEC_BIT_HIGH, NEC_BIT_LOW_0, NEC_BIT_HIGH, NEC_BIT_LOW_0};
    int dataLength = sizeof(data) / sizeof(data[0]);
    unsigned char result[4] = {0};
    decodeNEC(data, dataLength, result);
    unsigned char byte1 = result[0];
    unsigned char byte2 = result[1];
    unsigned char byte3 = result[2];
    unsigned char byte4 = result[3];
    return 0;
Post by mnfisher »
It would be nice as a component - the Arduino code above should convert fairly easily - but there is quite a lot of work to do (especially if you want to support different MCUs)
I'm very busy at present but if I get some spare time - which MCU are you using?
MJU20
Post by MJU20 »
I'm using an ESP32 right now.
But it's all about timing because it doesn't seem to be such a hard protocol to check??
Post by mnfisher »
It should be straightforward - the esp32 is quick enough to make the timing easy. If you want to be flash then you can use the RMT hardware too.
