Component Export with Scada
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Hi Team.
I received my genuine UNO R3 and all is working well :D now
Is my understanding correct after I did all the HW simulation and testing and want to export my final component I just need to delete the Injector and Scada slave components from the Panel so that they do not get exported as well .
When the user use the component and want to do HW simulation he then add the injector and Scada device of his choice to his project Correct ?
Has thanked: 724 times
Been thanked: 783 times
Re: Component Export with Scada
Hi Peter,
That is easily achieved.
After clicking Deploy as Flowcode App, Select the Components tab.
Just select all the components you don't want to appear then click >>
Flowcode app options.png (32.19 KiB) Viewed 6615 times
p.erasmus
Post by p.erasmus »
Hi Martin
Thank you this is good information, I am actually referring to when I made a I2C component in FC and used SCADA to talk to the I2C device during simulation and now the component is finished and I want to export the Component that it can be used in Flowcode so do I delete/remove the scada components or do I miss something from your post ,Thanks for your help Appreciated
:D :D :D
Hi Peter,
What I posted applies to when using an Arduino UNO as a slave being controller via the App developer.
when using the Deploy as a Flowcode APP.
When running the deployed app, anything that was added to the the Invisible components window, won't be seen on the panel.
When you shown remove then, I thought you meant from view.
If that is not what you meant then, my post will not apply.
Has thanked: 616 times
Been thanked: 814 times
Hi Peter,
Yes when creating a component source the injector / SCADA Slave is great for testing but once you're finished with the code they should be removed prior to exporting.
p.erasmus
Post by p.erasmus »
@Martin,
Your post apply very well for future things I still have do so many thanks, I appreciate this I did not know it :D
Ben,
Thanks it is clear appreciate :D
It has never been easier to do I2C and SPI code as with this scada setup I was sad that I had to spend many rubble for an Arduino, but now I am so happy I did,it is easier than working with a micro and debugging ,Flowcode has really expanded in a big way since V7 ,V7 was big jump from V6 but V9 is amazing thanks to you Ben and the Team at MATRIX ,FC is now a great tool :D :D :D :D :D :D
Logic Analyzer print from a Write/ Read operation on I2C at the device with SCADA Simulation :D :D
I am so happy
